Kalan2024
- 11 Сер 2024
- Ja Solar JAM72D40-595 Bifacial N-type
- Luxpower SNA5000 ,Phantom UPS-0512
1. Change the generator dry contact operating logic, now the remote start generator will base on the "Charge start SOC" under the GEN setting.
2. Fixed a bug that when upgrade new firmware for units in parallel system, some setting might be changed.
3. Fixed a bug that inverter report a overload warning by mistake.
4. Optimized the EPS overload trigger logic when the PV voltage is around to the start edge.
5. Fixed a bug that might restore some important setting when unit have a factory restore.
6. Optimized a over current issue when inverter is switching to EPS mode.
7. Fixed a issue that inverter will report battery open when the battery is turned on with fully charged.
8. Optimized the maximum PV input for single MPPT from 4.0KW to 4.8KW, the total maximum PV input will be 9.6KW now.
